Forthcompiler
A simple Forth compiler
Definitions
Everything inside ( ) is a comment When stack content is written on one line, the top of the stack is to the right bottom -> 1 2 3 <- top Stack diagrams are comments that show what is taken from the stack and what is returned ot the stack ( items read from the stack -- items written on the stack ) Examples: ( n n -- n ) This means that two numbers were read from the stack, then one number was written back. For example a simple addition reads two numbers and writes back the result. ( a b c -- c b a ) Reading threee values from the stack and write them back in the opposite order.
Compiler stage 1
- Tokenize the source by splitting it at whitespace, turning a string into a series of words
- Build a dictionary that contains all words and their definitions
Words
Data processing: + ( n n -- n ) ( : + >r 0 r> - - ; ) - ( n n -- n ) ( fundamental ) * ( n n -- n ) ( : * 0 do over 1 and if rot dup >r -rot r> + endif rot 1 lsl rot 1 lsr rot over if again endif >r drop -rot drop drop ; ) / ( n n -- n ) ( ? ) lsl ( n n -- n ) ( : lsl for dup + next ; ) lsr ( n n -- n ) ( : lsr for 31 for dup 0x80000000 and swap 1 lsl swap if 1 + endif next 0x7fffffff and next ; ) and ( n n -- n ) ( fundamental ) or ( n n -- n ) ( : or over not and + ; ) eor ( n n -- n ) ( : eor over over or -rot and not and ; ) not ( n -- n ) ( : not >r -1 r> - ; ) Stack manipulation: drop ( n -- ) ( : drop if endif ; ) dup ( n -- n n ) ( fundamental ) swap ( a b -- b a ) ( : swap dup >r >r dup r> eor dup >r eor r> r> eor ; ) over ( a b -- a b a ) ( : over >r dup r> swap ; ) rot ( a b c -- b c a ) ( : rot >r swap r> swap ; ) -rot ( a b c -- c a b ) ( : -rot swap >r swap r> ; ) >r ( n -- ) ( fundamental ) r> ( -- n ) ( fundamental )
