Arty S7
Jump to: navigation, search
  • 256 MB DDR3L memory and 16 MB Quad-SPI Flash
  • Programmable from JTAG and Quad-SPI flash
  • 100 MHz & 12MHz external clocks
  • Internal ADC Dual-channel, 1 MSPS
  • Powered from USB or any 7V-15V source
  • Interaction and Sensory Devices
    • 4 Switches
    • 4 Buttons
    • 1 Board Reset Button
    • 1 FPGA Reset Button
    • 4 Green LEDs
    • 2 RGB LEDs
  • Expansion Connectors:
XC7S50-1CSGA324C XC7S25-1CSGA324
Logic Slices 8150 3650
6-Input LUTs 32 600 14 600
Flip-Flops 65 200 29 200
Block RAM 75 * 4500 = 337.5 KByte 45 * 4500 = 202.5 KByte
DSP Slices 120 80
Clock resources 5 PLLs 3 PLLs
Pmod interface
Pinout of Pmod connector
3V3 GND d3 d2 d1 d0
3V3 GND d3 d2 d1 d0
  • The 6 pin interface is one horizontal row on the connector.
  • The 12 pin interface use both rows, a module can use several connectors.
  • Port JA and JB are unprotected and routed for high speed.
  • Port JC and JD are protected with 200 Ohm series resistors and are shared with the Arduino shield interface (IO34-IO41 IO26-IO33)
Pmod JA Pmod JB Pmod JC Pmod JD
Pmod Type High-Speed High-Speed Standard Standard
Series resistor 0 Ohm 0 Ohm 200 Ohm 200 Ohm
Shared pins IO34-IO41 IO26-IO33
Pin 1 L17 P17 U15 V15
Pin 2 L18 P18 V16 U12
Pin 3 M14 R18 U17 V13
Pin 4 N14 T18 U18 T12
Pin 7 M16 P14 U16 T13
Pin 8 M17 P15 P13 R11
Pin 9 M18 N15 R13 T11
Pin 10 N18 P16 V14 U11
Arduino shield/chipKIT interface
45 total FPGA I/O (16 shared with Pmod connectors - IO34-IO41 IO26-IO33)
6 Single-ended 0-3.3V Analog inputs to XADC
3 (4 *S7-25) Differential 0-1.0V Analog input pairs to XADC
USB-UART bridge
  • FTDI FT2232HQ USB-UART bridge with both JTAG and RS-232 ports
  • JTAG is connected to the JTAG port on the FPGA
  • RS-232 is connected to pin V12 and R12
  • Two on-board status LEDs: the transmit LED (LD8) and the receive LED (LD7) (relative to the PC).
  • Speed up to 12 MBit/s
Block RAM
Each block RAM stores up to 36 Kbits of dual ported RAM and has a FIFO controller and a ECC unit.
Each 36 Kbit block can be configured as two independent 18 Kb dual ported RAM.
Two adjacent 36 Kbit blocks can be configured as a 64Kb x 1 RAM.
Each 36 Kbit block RAM can be configured as a 32K x 1, 16K x 2, 8K x 4, 4K x 9, 2K x 18, 1K x 36, or 512 x 72 in simple dual-port mode.
Each 18 Kbit block RAM can be configured as a 16K x 1, 8K x2 , 4K x 4, 2K x 9, 1K x 18 or 512 x 36 in simple dual-port mode.
DSP48E1 slice
DSP48E1 slice
  • 25-bit pre-adder with D register to enhance the capabilities of the A path
  • INMODE control supports balanced pipelining when dynamically switching between multiply (A*B) and add operations (A:B)
  • 25 x 18 multiplier
  • 30-bit A input of which the lower 25 bits feed the A input of the multiplier, and the entire 30-bit input forms the upper 30 bits of the 48-bit A:B concatenate internal bus.
  • Cascading A and B input
    • Semi-independently selectable pipelining between direct and cascade paths
    • Separate clock enables two-deep A and B set of input registers
  • Independent C input and C register with independent reset and clock enable.
  • CARRYCASCIN and CARRYCASCOUT internal cascade signals to support 96-bit accumulators/adders/subtracters in two DSP48E1 slices
  • MULTSIGNIN and MULTSIGNOUT internal cascade signals with special OPMODE setting to support a 96-bit MACC extension
  • Single Instruction Multiple Data (SIMD) Mode for three-input adder/subtracter which precludes use of multiplier in first stage
    • Dual 24-bit SIMD adder/subtracter/accumulator with two separate CARRYOUT signals
    • Quad 12-bit SIMD adder/subtracter/accumulator with four separate CARRYOUT signals
  • 48-bit logic unit
    • Bitwise logic operations – two-input AND, OR, NOT, NAND, NOR, XOR, and XNOR
    • Logic unit mode dynamically selectable via ALUMODE
  • Pattern detector
    • Overflow/underflow support
    • Convergent rounding support
    • Terminal count detection support and auto resetting
  • Cascading 48-bit P bus supports internal low-power adder cascade
    • The 48-bit P bus allows for 12-bit/QUAD or 24-bit/DUAL SIMD adder cascade support
  • Optional 17-bit right shift to enable wider multiplier implementation
  • Dynamic user-controlled operating modes
    • 7-bit OPMODE control bus provides X, Y, and Z multiplexer select signals
  • Carry in for the second stage adder
    • Support for rounding
    • Support for wider add/subtracts
    • 3-bit CARRYINSEL multiplexer
  • Carry out for the second stage adder
    • Available for each SIMD adder (up to four)
    • Cascaded CARRYCASCOUT and MULTSIGNOUT allows for MACC extensions up to 96 bits
  • Optional input, pipeline, and output/accumulate registers
  • Optional control registers for control signals (OPMODE, ALUMODE, and CARRYINSEL)
  • Independent clock enable and resets for greater flexibility, with reset having priority.
  • To save power when the first stage multiplier is not being used, the USE_MULT attribute allows the customer to gate off internal multiplier logic.
Files and information
