Verilog
Contents
- 1 Sensitivity list
- 2 Assignment
- 3 Wire, reg, tri
- 4 For, while, forever
- 5 Input, inout, output
- 6 If else
- 7 Case end
- 8 Reduction operators
- 9 Logical operations
- 10 Bitwise operations
- 11 Shifts
- 12 Conditional ?:
- 13 Replication {n{}}
- 14 Concatenation {,}
- 15 Literals
- 16 Arrays
- 17 Blocks
- 18 Modules
- 19 Testbench
- 20 Operation Size and Sign Extension
Sensitivity list
- the list is only sensitive to changes in the operation result, not the operands
Assignment
Combinational logic is implemented by Boolean circuits, where the output is a pure function of the present input only. In sequential logic the output not only depends on the present input but also on the history of the input. Sequential logic has memory while combinational logic does not.
Continuous Assignment
- Order doesn’t matter because of concurrent execution
- Syntax is "assign LHS = RHS" where LHS is a wire/bus and RHS is an expression
wire [8:0] sum; // Output bus wire [7:0] a, b; // Input busses wire cin; // Carry input assign sum = a + b + cin; // sum is recomputed when a, b, or cin change
Procedural Assignment
Inside an initial or always block: sum = a + b + cin; (Blocking assignment, RHS evaluated and assigned to LHS before next statement) RHS (Right Hand side of equation / assignment) may contain wires and regs LHS (Left Hand side) must be a reg Primitives or assignment may set wire values?
Wire, reg, tri
wire a; // Simple wire tri [15:0] dbus; // 16-bit tristate bus reg [-1:4] vec; // Six-bit register integer imem[0:1023]; // Array of 1024 integers reg [31:0] dcache[0:63]; // A 32-bit memory with 64 words
For, while, forever
While and forever loops must contain @(posedge clk) or @(negedge clk)
If else
Case end
Reduction operators
& AND &(4’b0101) = 0 & 1 & 0 & 1 = 1’b0 ~& NAND | OR ~| NOR ^ XOR ~^ XNOR ^~ XNOR
Logical operations
Logical Negation ! Logical AND && Logical OR || Logical Equality == Logical Inequality !=
Bitwise operations
Bitwise Negation ~ Bitwise AND & Bitwise Inclusive OR | Bitwise Exclusive OR ^ Bitwise Equivalence ~^, ^~
Shifts
8'h12 << 4 = 8'h20 8'h12 >> 4 = 8'h01
Conditional ?:
CASE statement and if/else statements are recommended for inferring MUX
Replication {n{}}
{4{2'b01}} = 8'b01010101
Concatenation {,}
{2'b01, 4'hF, 1'b1, 1'b0} = 8'b01111110
Literals
- Literal number syntax is: <size>’<signed><base><value>
- <size> (optional) is the number of bits (default size is 32 bits)
- <signed> (optional) is the letter s or S (default is unsigned)
- <base> is b, o, d, h for binary, octal, decimal or hex (not case sensitive)
- If the size does not match the number of bits in the value:
- If the left-most bit of value is 0 or 1, the value is left-extended with 0
- If the left-most bit of value is Z, the value is left-extended with Z
- If the left-most bit of value is X, the value is left-extended with X
- A signed value is not sign-extended!
Base Symbol Legal Values binary b or B 0, 1, x, X, z, Z, ?, _ octal o or O 0-7, x, X, z, Z, ?, _ decimal d or D 0-9, _ hexadecimal h or H 0-9, a-f, A-F, x, X, z, Z, ?, _ Examples 8'b11111111 = 255 32'hBAADF00D = 3 131 961 357 123_456 = 123 567
Arrays
reg [3:0] name [31:0];
The above describes an array of 32 Elements each, 4 bits wide which can be assigned via behavioral Verilog code.
Blocks
Block statements are used to group statements together. XST only supports sequential blocks. Within these blocks, the statements are executed in the order listed. Parallel blocks are not supported by XST. Block statements are designated by begin and end keywords, and are discussed within examples later in this chapter.
Modules
In Verilog a design component is represented by a module. The connections between components are specified within module instantiation statements. Such a statement specifies an instance of a module. Each module instantiation statement must be given a name (instance name). In addition to the name, a module instantiation statement contains an association list that specifies which actual nets or ports are associated with which local ports (formals) of the module declaration.
All procedural statements occur in blocks that are defined inside modules. There are two kinds of procedural blocks: the initial block and the always block. Within each block, Verilog uses a begin and end to enclose the statements. Since initial blocks are ignored during synthesis, only always blocks are discussed. Always blocks usually take the following format:
always begin statement ... end
where each statement is a procedural assignment line terminated by a semicolon.
Testbench
reg clk; initial // clock generation begin clk = 0; forever #10 clk = ~clk; end initial begin @(posedge clk); while(value==0) @(posedge clk); repeat(100) @(posedge clk); $stop; $finish; end
Table 4_3 Expression Bit-Widths | ||
Expression | Bit Length | Comments |
unsized constant | 32-bit | self-determined |
sized constant | as specified | self-determined |
i + j | max(L(i),L(j)) | context-determined |
i - j | max(L(i),L(j)) | context-determined |
i * j | max(L(i),L(j)) | context-determined |
i / j | max(L(i),L(j)) | context-determined |
i % j | max(L(i),L(j)) | context-determined |
i & j | max(L(i),L(j)) | context-determined |
i ^ j | max(L(i),L(j)) | context-determined |
i ^~ j | max(L(i),L(j)) | context-determined |
~i | L(i) | context-determined |
i == j | 1-bit | self-determined |
i !== j | 1-bit | self-determined |
i && j | 1-bit | self-determined |
i || j | 1-bit | self-determined |
i > j | 1-bit | self-determined |
i >= j | 1-bit | self-determined |
i < j | 1-bit | self-determined |
i <= j | 1-bit | self-determined |
&i | 1-bit | self-determined |
^i | 1-bit | self-determined |
~&i | 1-bit | self-determined |
~^i | 1-bit | self-determined |
i >> j | L(i) | j is self-determined |
{i{j}} | i*L(j) | j is self-determined |
i << j | L(i) | j is self-determined |
i ? j : k | Max(L(j),L(k)) | j is self-determined |
{i,...,j} | L(i)+...+L(j) | self-determined |
{i {j,...,k}} | /*(L(j)+...+L(k)) | self-determined |
