STM32F407 Microcontroller
Contents
STM32F407VG Microcontroller Overview
High-performance and DSP with FPU, ARM Cortex-M4 MCU with 1 Mbyte Flash, 192 Kbyte RAM, 168 MHz CPU, Art Accelerator
- 1 Mbyte of 128 bit wide FLASH with 64 cache lines with prefetch for instructions and 8 cache lines for data.
- Ethernet MAC - 10/100 Mbit/s
- USB - 1 x USB OTG FS, 1 x USB OTX HS
- CRC calculation unit - CRC-32 (Ethernet)
- Hash processor - SHA-1, SHA-224, SHA-256, MD5, HMAC
- Cryptographic processor - DES, Triple-DES, AES-128, AES-192, AES-256
- Flexible static memory controller (FSMC) for 8 or 16 bit external memory
- Random number generator - 32 bit every 40 cycles of PLL48CLK
Documents and files
- ARM: Cortex-M3 Thumb-2 instruction set
- Latest version of Keil µVision (Register for free to get the download link)
- STM32F407VG microcontroller datasheet
- ARM Cortex®-M4 Technical Reference Manual
- STM32F40xxx Reference Manual
- Programming manual
- STM32F407VG resources (click the Design Resources tab)
GPIO
The GPIOs (general purpose input/outputs) can sink or source up to ±8 mA, and sink or source up to ±20 mA (with a relaxed VOL/VOH) except PC13, PC14 and PC15 which can sink or source up to ±3mA. When using the PC13 to PC15 GPIOs in output mode, the speed should not exceed 2 MHz with a maximum load of 30 pF.
Memory
Each main block of memory is on a different layer of the bus matrix and can be accessed independently by CPU core or DMA.
Embedded Flash Name Address Size Bus* Description Main 0x0800 0000 1MB ID Sectors: 4 x 16KB, 1 x 64KB, 7 x 128KB System 0x1FFF 0000 30KB ID Bootloader OTP 0x1FFF 7800 528B ID 512 Bytes of one-time programmable memory for user data and 16 lock bytes Option 0x1FFF C000 16B ID Configuration of read and write protection, BOR level, watchdog, software/hardware and reset SRAM Name Address Size Bus Description SRAM1 0x2000 0000 112KB IDS Main internal SRAM SRAM2 0x2001 C000 16KB S Auxiliary internal SRAM CCM 0x1000 0000 64KB D Core coupled memory ( only accessible by CPU ) BKPSRAM 0x4002 4000 4KB S Backup SRAM ( Battery backup domain ) FSMC B1 0x6000 0000 256MB IDS NOR / PSRAM ( Flexible static memory controller (External memory) ) FSMC B2 0x7000 0000 256MB IDS NAND Flash FSMC B3 0x8000 0000 256MB IDS NAND Flash FSMC B4 0x9000 0000 256MB IDS PC Card *I = Instruction bus, D = Data bus, S = System bus
Pin functions
- Functions are not in any particular order. For actual implementation and programming values, see Alternate function mapping
Pin | Function 1 | Function 2 | Function 3 | Function 4 | Function 5 | Function 6 | Function 7 | Function 8 | Function 9 | Function 10 | Function 11 | Notes |
PA0 | USART2_CTS | UART4_TX | ETH_MII_CRS | TIM2_CH1_ETR | TIM5_CH1 | TIM8_ETR | EVENTOUT | ADC123_IN0 | WKUP(4) |
PA1 | USART2_RTS | UART4_RX | ETH_RMII_REF_CLK | ETH_MII_RX_CLK | TIM5_CH2 | TIM2_CH2 | EVENTOUT | ADC123_IN1 |
PA2 | USART2_TX | TIM5_CH3 | TIM9_CH1 | TIM2_CH3 | ETH_MDIO | EVENTOUT | ADC123_IN2 |
PA3 | USART2_RX | TIM5_CH4 | TIM9_CH2 | TIM2_CH4 | OTG_HS_ULPI_D0 | ETH_MII_COL | EVENTOUT | ADC123_IN3 |
PA4 | SPI1_NSS | SPI3_NSS | USART2_CK | DCMI_HSYNC | OTG_HS_SOF | I2S3_WS | EVENTOUT | ADC12_IN4 | DAC_OUT1 |
PA5 | SPI1_SCK | OTG_HS_ULPI_CK | TIM2_CH1_ETR | TIM8_CH1N | EVENTOUT | ADC12_IN5 | DAC_OUT2 |
PA6 | SPI1_MISO | TIM8_BKIN | TIM13_CH1 | DCMI_PIXCLK | TIM3_CH1 | TIM1_BKIN | EVENTOUT | ADC12_IN6 |
PA7 | SPI1_MOSI | TIM8_CH1N | TIM14_CH1 | TIM3_CH2 | ETH_MII_RX_DV | TIM1_CH1N | ETH_RMII_CRS_DV | EVENTOUT | ADC12_IN7 |
PA8 | MCO1 | USART1_CK | TIM1_CH1 | I2C3_SCL | OTG_FS_SOF | EVENTOUT |
PA9 | USART1_TX | TIM1_CH2 | I2C3_SMBA | DCMI_D0 | EVENTOUT | OTG_FS_VBUS |
PA10 | USART1_RX | TIM1_CH3 | OTG_FS_ID | DCMI_D1 | EVENTOUT |
PA11 | USART1_CTS | CAN1_RX | TIM1_CH4 | OTG_FS_DM | EVENTOUT |
PA12 | USART1_RTS | CAN1_TX | TIM1_ETR | OTG_FS_DP | EVENTOUT |
PA13 | JTMS-SWDIO | EVENTOUT |
PA14 | JTCK-SWCLK | EVENTOUT |
PA15 | JTDI | SPI3_NSS | I2S3_WS | TIM2_CH1_ETR | SPI1_NSS | EVENTOUT |
PB0 | TIM3_CH3 | TIM8_CH2N | OTG_HS_ULPI_D1 | ETH_MII_RXD2 | TIM1_CH2N | EVENTOUT | ADC12_IN8 |
PB1 | TIM3_CH4 | TIM8_CH3N | OTG_HS_ULPI_D2 | ETH_MII_RXD3 | TIM1_CH3N | EVENTOUT | ADC12_IN9 |
PB2 | BOOT1 | EVENTOUT |
PB3 | JTDO | TRACESWO | SPI3_SCK | I2S3_CK | TIM2_CH2 | SPI1_SCK | EVENTOUT |
PB4 | NJTRST | SPI3_MISO | TIM3_CH1 | SPI1_MISO | I2S3ext_SD | EVENTOUT |
PB5 | I2C1_SMBA | CAN2_RX | OTG_HS_ULPI_D7 | ETH_PPS_OUT | TIM3_CH 2 | SPI1_MOSI | SPI3_MOSI | DCMI_D10 | I2S3_SD | EVENTOUT |
PB6 | I2C1_SCL | TIM4_CH1 | CAN2_TX | DCMI_D5 | USART1_TX | EVENTOUT |
PB7 | I2C1_SDA | FSMC_NL | DCMI_VSYNC | USART1_RX | TIM4_CH2 | EVENTOUT |
PB8 | TIM4_CH3 | SDIO_D4 | TIM10_CH1 | DCMI_D6 | ETH_MII_TXD3 | I2C1_SCL | CAN1_RX | EVENTOUT |
PB9 | SPI2_NSS | I2S2_WS | TIM4_CH4 | TIM11_CH1 | SDIO_D5 | DCMI_D7 | I2C1_SDA | CAN1_TX | EVENTOUT |
PB10 | SPI2_SCK | I2S2_CK | I2C2_SCL | USART3_TX | OTG_HS_ULPI_D3 | ETH_MII_RX_ER | TIM2_CH3 | EVENTOUT |
PB11 | I2C2_SDA | USART3_RX | OTG_HS_ULPI_D4 | ETH_RMII_TX_EN | ETH_MII_TX_EN | TIM2_CH4 | EVENTOUT |
PB12 | SPI2_NSS | I2S2_WS | I2C2_SMBA | USART3_CK | TIM1_BKIN | CAN2_RX | OTG_HS_ULPI_D5 | ETH_RMII_TXD0 | ETH_MII_TXD0 | OTG_HS_ID | EVENTOUT |
PB13 | SPI2_SCK | I2S2_CK | USART3_CTS | TIM1_CH1N | CAN2_TX | OTG_HS_ULPI_D6 | ETH_RMII_TXD1 | ETH_MII_TXD1 | EVENTOUT | OTG_HS_VBUS |
PB14 | SPI2_MISO | TIM1_CH2N | TIM12_CH1 | OTG_HS_DM | USART3_RTS | TIM8_CH2N | I2S2ext_SD | EVENTOUT |
PB15 | SPI2_MOSI | I2S2_SD | TIM1_CH3N | TIM8_CH3N | TIM12_CH2 | OTG_HS_DP | EVENTOUT | RTC_REFIN |
PC0 | OTG_HS_ULPI_STP | EVENTOUT | ADC123_IN10 |
PC1 | ETH_MDC | EVENTOUT | ADC123_IN11 |
PC2 | SPI2_MISO | OTG_HS_ULPI_DIR | ETH_MII_TXD2 | I2S2ext_SD | EVENTOUT | ADC123_IN12 |
PC3 | SPI2_MOSI | I2S2_SD | OTG_HS_ULPI_NXT | ETH_MII_TX_CLK | EVENTOUT | ADC123_IN13 |
PC4 | ETH_RMII_RX_D0 | ETH_MII_RX_D0 | EVENTOUT | ADC12_IN14 |
PC5 | ETH_RMII_RX_D1 | ETH_MII_RX_D1 | EVENTOUT | ADC12_IN15 |
PC6 | I2S2_MCK | TIM8_CH1 | SDIO_D6 | USART6_TX | DCMI_D0 | TIM3_CH1 | EVENTOUT |
PC7 | I2S3_MCK | TIM8_CH2 | SDIO_D7 | USART6_RX | DCMI_D1 | TIM3_CH2 | EVENTOUT |
PC8 | TIM8_CH3 | SDIO_D0 | TIM3_CH3 | USART6_CK | DCMI_D2 | EVENTOUT |
PC9 | I2S_CKIN | MCO2 | TIM8_CH4 | SDIO_D1 | I2C3_SDA | DCMI_D3 | TIM3_CH4 | EVENTOUT |
PC10 | SPI3_SCK | I2S3_CK | UART4_TX | SDIO_D2 | DCMI_D8 | USART3_TX | EVENTOUT |
PC11 | UART4_RX | SPI3_MISO | SDIO_D3 | DCMI_D4 | USART3_RX | I2S3ext_SD | EVENTOUT |
PC12 | UART5_TX | SDIO_CK | DCMI_D9 | SPI3_MOSI | I2S3_SD | USART3_CK | EVENTOUT |
PC13 | EVENTOUT | RTC_OUT | RTC_TAMP1 | RTC_TS |
PC14 | EVENTOUT | OSC32_IN(4) |
PC15 | EVENTOUT | OSC32_OUT(4) |
PD0 | FSMC_D2 | CAN1_RX | EVENTOUT |
PD1 | FSMC_D3 | CAN1_TX | EVENTOUT |
PD2 | TIM3_ETR | UART5_RX | SDIO_CMD | DCMI_D11 | EVENTOUT |
PD3 | FSMC_CLK | USART2_CTS | EVENTOUT |
PD4 | FSMC_NOE | USART2_RTS | EVENTOUT |
PD5 | FSMC_NWE | USART2_TX | EVENTOUT |
PD6 | FSMC_NWAIT | USART2_RX | EVENTOUT |
PD7 | USART2_CK | FSMC_NE1 | FSMC_NCE2 | EVENTOUT |
PD8 | FSMC_D13 | USART3_TX | EVENTOUT |
PD9 | FSMC_D14 | USART3_RX | EVENTOUT |
PD10 | FSMC_D15 | USART3_CK | EVENTOUT |
PD11 | FSMC_CLE | FSMC_A16 | USART3_CT S | EVENTOUT |
PD12 | FSMC_ALE | FSMC_A17 | TIM4_CH1 | USART3_RTS | EVENTOUT |
PD13 | FSMC_A18 | TIM4_CH2 | EVENTOUT |
PD14 | FSMC_D0 | TIM4_CH3 | EVENTOUT | EVENTOUT |
PD15 | FSMC_D1 | TIM4_CH4 | EVENTOUT |
PE0 | TIM4_ETR | FSMC_NBL0 | DCMI_D2 | EVENTOUT |
PE1 | FSMC_NBL1 | DCMI_D3 | EVENTOUT |
PE2 | TRACECLK | FSMC_A23 | ETH_MII_TXD3 | EVENTOUT |
PE3 | TRACED0 | FSMC_A19 | EVENTOUT |
PE4 | TRACED1 | FSMC_A20 | DCMI_D4 | EVENTOUT |
PE5 | TRACED2 | FSMC_A21 | TIM9_CH1 | DCMI_D6 | EVENTOUT |
PE6 | TRACED3 | FSMC_A22 | TIM9_CH2 | DCMI_D7 | EVENTOUT |
PE7 | FSMC_D4 | TIM1_ETR | EVENTOUT |
PE8 | FSMC_D5 | TIM1_CH1N | EVENTOUT |
PE9 | FSMC_D6 | TIM1_CH1 | EVENTOUT |
PE10 | FSMC_D7 | TIM1_CH2N | EVENTOUT |
PE11 | FSMC_D8 | TIM1_CH2 | EVENTOUT |
PE12 | FSMC_D9 | TIM1_CH3N | EVENTOUT |
PE13 | FSMC_D10 | TIM1_CH3 | EVENTOUT |
PE14 | FSMC_D11 | TIM1_CH4 | EVENTOUT |
PE15 | FSMC_D12 | TIM1_BKIN | EVENTOUT |
PH0 | EVENTOUT | OSC_IN(4) |
PH1 | EVENTOUT | OSC_OUT(4) |
Pin | AF 0 | AF 1 | AF 2 | AF 3 | AF 4 | AF 5 | AF 6 | AF 7 | AF 8 | AF 9 | AF 10 | AF 11 | AF 12 | AF 13 | AF 14 | AF 15 |
SYS | TIM1/2 | TIM3/4/5 | TIM8/9/10/11 | I2C1/2/3 | SPI1/SPI2/I2S2/I2S2ext | SPI3/I2Sext/I2S3 | USART1/2/3/I2S3ext | UART4/5/USART6 | CAN1/CAN2/TIM12/13/14 | OTG_FS/OTG_HS | ETH | FSMC/SDIO/OTG_FS | DCMI | |||
PA0 | TIM2_CH1_ETR | TIM5_CH1 | TIM8_ETR | USART2_CTS | UART4_TX | ETH_MII_CRS | EVENTOUT | |||||||||
PA1 | TIM2_CH2 | TIM5_CH2 | USART2_RTS | UART4_RX | ETH_MII_RX_CLK ETH_RMII_REF_CLK |
EVENTOUT | ||||||||||
PA2 | TIM2_CH3 | TIM5_CH3 | TIM9_CH1 | USART2_TX | ETH_MDIO | EVENTOUT | ||||||||||
PA3 | TIM2_CH4 | TIM5_CH4 | TIM9_CH2 | USART2_RX | OTG_HS_ULPI_D0 | ETH _MII_COL | EVENTOUT | |||||||||
PA4 | SPI1_NSS | SPI3_NSS I2S3_WS |
USART2_CK | OTG_HS_SOF | DCMI_HSYNC | EVENTOUT | ||||||||||
PA5 | TIM2_CH1_ETR | TIM8_CH1N | SPI1_SCK | OTG_HS_ULPI_CK | EVENTOUT | |||||||||||
PA6 | TIM1_BKIN | TIM3_CH1 | TIM8_BKIN | SPI1_MISO | TIM13_CH1 | DCMI_PIXCK | EVENTOUT | |||||||||
PA7 | TIM1_CH1N | TIM3_CH2 | TIM8_CH1N | SPI1_MOSI | TIM14_CH1 | ETH_MII_RX_DV ETH_RMII_CRS_DV |
PA8 | MCO1 | TIM1_CH1 | I2C3_SCL | USART1_CK | OTG_FS_SOF | EVENTOUT | ||||||||||
PA9 | TIM1_CH2 | I2C3_SMBA | USART1_TX | DCMI_D0 | EVENTOUT | |||||||||||
PA10 | TIM1_CH3 | USART1_RX | OTG_FS_ID | DCMI_D1 | EVENTOUT | |||||||||||
PA11 | TIM1_CH4 | USART1_CTS | CAN1_RX | OTG_FS_DM | EVENTOUT | |||||||||||
PA12 | TIM1_ETR | USART1_RTS | CAN1_TX | OTG_FS_DP | EVENTOUT | |||||||||||
PA13 | JTMS-SWDIO | |||||||||||||||
PA14 | JTCK-SWCLK | |||||||||||||||
PA15 | JTDI | TIM2_CH1 TIM2_ETR |
PB0 | TIM1_CH2N | TIM3_CH3 | TIM8_CH2N | OTG_HS_ULPI_D1 | ETH _MII_RXD2 | EVENTOUT | ||||||||||
PB1 | TIM1_CH3N | TIM3_CH4 | TIM8_CH3N | OTG_HS_ULPI_D2 | ETH_MII_RXD3 | EVENTOUT | ||||||||||
PB2 | EVENTOUT | |||||||||||||||
PB3 | JTDO TRACESWO |
TIM2_CH2 | SPI1_SCK | SPI3_SCK I2S3_CK |
PB4 | NJTRST | TIM3_CH1 | SPI1_MISO | SPI3_MISO | I2S3ext_SD | EVENTOUT | ||||||||||
PB5 | TIM3_CH2 | I2C1_SMBA | SPI1_MOSI | SPI3_MOSI I2S3_SD |
CAN2_RX | OTG_HS_ULPI_D7 | ETH_PPS_OUT | DCMI_D10 | EVENTOUT | |||||||
PB6 | TIM4_CH1 | I2C1_SCL | USART1_TX | CAN2_TX | DCMI_D5 | EVENTOUT | ||||||||||
PB7 | TIM4_CH2 | I2C1_SDA | USART1_RX | FSMC_NL | DCMI_VSYNC | EVENTOUT | ||||||||||
PB8 | TIM4_CH3 | TIM10_CH1 | I2C1_SCL | CAN1_RX | ETH _MII_TXD3 | SDIO_D4 | DCMI_D6 | EVENTOUT | ||||||||
PB9 | TIM4_CH4 | TIM11_CH1 | I2C1_SDA | SPI2_NSS I2S2_WS |
CAN1_TX | SDIO_D5 | DCMI_D7 | EVENTOUT | ||||||||
PB10 | TIM2_CH3 | I2C2_SCL | SPI2_SCK I2S2_CK |
USART3_TX | OTG_HS_ULPI_D3 | ETH_MII_RX_ER | EVENTOUT | |||||||||
PB11 | TIM2_CH4 | I2C2_SDA | USART3_RX | OTG_HS_ULPI_D4 | ETH_MII_TX_EN ETH_RMII_TX_EN |
PB12 | TIM1_BKIN | I2C2_SMBA | SPI2_NSS I2S2_WS |
USART3_CK | CAN2_RX | OTG_HS_ULPI_D5 | ETH_MII_TXD0 ETH_RMII_TXD0 |
OTG_HS_ID | EVENTOUT | |||||||
PB13 | TIM1_CH1N | SPI2_SCK I2S2_CK |
USART3_CTS | CAN2_TX | OTG_HS_ULPI_D6 | ETH_MII_TXD1 ETH_RMII_TXD1 |
PB14 | TIM1_CH2N | TIM8_CH2N | SPI2_MISO | I2S2ext_SD | USART3_RTS | TIM12_CH1 | OTG_HS_DM | EVENTOUT | ||||||||
PB15 | RTC_REFIN | TIM1_CH3N | TIM8_CH3N | SPI2_MOSI I2S2_SD |
TIM12_CH2 | OTG_HS_DP | EVENTOUT | |||||||||
PC0 | OTG_HS_ULPI_STP | EVENTOUT | ||||||||||||||
PC1 | ETH_MDC | EVENTOUT | ||||||||||||||
PC2 | SPI2_MISO | I2S2ext_SD | OTG_HS_ULPI_DIR | ETH _MII_TXD2 | EVENTOUT | |||||||||||
PC3 | SPI2_MOSI I2S2_SD |
OTG_HS_ULPI_NXT | ETH_MII_TX_CLK | EVENTOUT | ||||||||||||
PC4 | ETH_MII_RXD0 ETH_RMII_RXD0 |
PC5 | ETH _MII_RXD1 ETH _RMII_RXD1 |
PC6 | TIM3_CH1 | TIM8_CH1 | I2S2_MCK | USART6_TX | SDIO_D6 | DCMI_D0 | EVENTOUT | |||||||||
PC7 | TIM3_CH2 | TIM8_CH2 | I2S3_MCK | USART6_RX | SDIO_D7 | DCMI_D1 | EVENTOUT | |||||||||
PC8 | TIM3_CH3 | TIM8_CH3 | USART6_CK | SDIO_D0 | DCMI_D2 | EVENTOUT | ||||||||||
PC9 | MCO2 | TIM3_CH4 | TIM8_CH4 | I2C3_SDA | I2S_CKIN | SDIO_D1 | DCMI_D3 | EVENTOUT | ||||||||
PC10 | SPI3_SCK I2S3_CK |
USART3_TX | UART4_TX | SDIO_D2 | DCMI_D8 | EVENTOUT | ||||||||||
PC11 | I2S3ext_SD | SPI3_MISO | USART3_RX | UART4_RX | SDIO_D3 | DCMI_D4 | EVENTOUT | |||||||||
PC12 | SPI3_MOSI I2S3_SD |
USART3_CK | UART5_TX | SDIO_CK | DCMI_D9 | EVENTOUT | ||||||||||
PC13 | EVENTOUT | |||||||||||||||
PC14 | EVENTOUT | |||||||||||||||
PC15 | EVENTOUT | |||||||||||||||
PD0 | CAN1_RX | FSMC_D2 | EVENTOUT | |||||||||||||
PD1 | CAN1_TX | FSMC_D3 | EVENTOUT | |||||||||||||
PD2 | UART5_RX | SDIO_CMD | DCMI_D11 | EVENTOUT | ||||||||||||
PD3 | USART2_CTS | FSMC_CLK | EVENTOUT | |||||||||||||
PD4 | USART2_RTS | FSMC_NOE | EVENTOUT | |||||||||||||
PD5 | USART2_TX | FSMC_NWE | EVENTOUT | |||||||||||||
PD6 | USART2_RX | FSMC_NWAIT | EVENTOUT | |||||||||||||
PD7 | USART2_CK | FSMC_NE1 FSMC_NCE2 |
PD8 | USART3_TX | FSMC_D13 | EVENTOUT | |||||||||||||
PD9 | USART3_RX | FSMC_D14 | EVENTOUT | |||||||||||||
PD10 | USART3_CK | FSMC_D15 | EVENTOUT | |||||||||||||
PD11 | USART3_CTS | FSMC_A16 | EVENTOUT | |||||||||||||
PD12 | TIM4_CH1 | USART3_RTS | FSMC_A17 | EVENTOUT | ||||||||||||
PD13 | TIM4_CH2 | FSMC_A18 | EVENTOUT | |||||||||||||
PD14 | TIM4_CH3 | FSMC_D0 | EVENTOUT | |||||||||||||
PD15 | TIM4_CH4 | FSMC_D1 | EVENTOUT | |||||||||||||
PE0 | TIM4_ETR | FSMC_NBL0 | DCMI_D2 | EVENTOUT | ||||||||||||
PE1 | FSMC_NBL1 | DCMI_D3 | EVENTOUT | |||||||||||||
PE2 | TRACECLK | ETH _MII_TXD3 | FSMC_A23 | EVENTOUT | ||||||||||||
PE3 | TRACED0 | FSMC_A19 | EVENTOUT | |||||||||||||
PE4 | TRACED1 | FSMC_A20 | DCMI_D4 | EVENTOUT | ||||||||||||
PE5 | TRACED2 | TIM9_CH1 | FSMC_A21 | DCMI_D6 | EVENTOUT | |||||||||||
PE6 | TRACED3 | TIM9_CH2 | FSMC_A22 | DCMI_D7 | EVENTOUT | |||||||||||
PE7 | TIM1_ETR | FSMC_D4 | EVENTOUT | |||||||||||||
PE8 | IM1_CH1N | FSMC_D5 | EVENTOUT | |||||||||||||
PE9 | TIM1_CH1 | FSMC_D6 | EVENTOUT | |||||||||||||
PE10 | TIM1_CH2N | FSMC_D7 | EVENTOUT | |||||||||||||
PE11 | TIM1_CH2 | FSMC_D8 | EVENTOUT | |||||||||||||
PE12 | TIM1_CH3N | FSMC_D9 | EVENTOUT | |||||||||||||
PE13 | TIM1_CH3 | FSMC_D10 | EVENTOUT | |||||||||||||
PE14 | TIM1_CH4 | FSMC_D11 | EVENTOUT | |||||||||||||
PE15 | TIM1_BKIN | FSMC_D12 | EVENTOUT | |||||||||||||
PF0 | I2C2_SDA | FSMC_A0 | EVENTOUT | |||||||||||||
PF1 | I2C2_SCL | FSMC_A1 | EVENTOUT | |||||||||||||
PF2 | 2C2_SMBA | FSMC_A2 | EVENTOUT | |||||||||||||
PF3 | FSMC_A3 | EVENTOUT | ||||||||||||||
PF4 | FSMC_A4 | EVENTOUT | ||||||||||||||
PF5 | FSMC_A5 | EVENTOUT | ||||||||||||||
PF6 | TIM10_CH1 | FSMC_NIORD | EVENTOUT | |||||||||||||
PF7 | TIM11_CH1 | FSMC_NREG | EVENTOUT | |||||||||||||
PF8 | TIM13_CH1 | FSMC_NIOWR | EVENTOUT | |||||||||||||
PF9 | TIM14_CH1 | FSMC_CD | EVENTOUT | |||||||||||||
PF10 | FSMC_INTR | EVENTOUT | ||||||||||||||
PF11 | DCMI_D12 | EVENTOUT | ||||||||||||||
PF12 | FSMC_A6 | EVENTOUT | ||||||||||||||
PF13 | FSMC_A7 | EVENTOUT | ||||||||||||||
PF14 | FSMC_A8 | EVENTOUT | ||||||||||||||
PF15 | FSMC_A9 | EVENTOUT | ||||||||||||||
PG0 | FSMC_A10 | EVENTOUT | ||||||||||||||
PG1 | FSMC_A11 | EVENTOUT | ||||||||||||||
PG2 | FSMC_A12 | EVENTOUT | ||||||||||||||
PG3 | FSMC_A13 | EVENTOUT | ||||||||||||||
PG4 | FSMC_A14 | EVENTOUT | ||||||||||||||
PG5 | FSMC_A15 | EVENTOUT | ||||||||||||||
PG6 | FSMC_INT2 | EVENTOUT | ||||||||||||||
PG7 | USART6_CK | FSMC_INT3 | EVENTOUT | |||||||||||||
PG8 | USART6_RTS | ETH _PPS_OUT | EVENTOUT | |||||||||||||
PG9 | USART6_RX | FSMC_NE2 FSMC_NCE3 |
PG10 | FSMC_NCE4_1 FSMC_NE3 |
PG11 | ETH _MII_TX_EN ETH _RMII_TX_EN |
FSMC_NCE4_2 | EVENTOUT | |||||||||||||
PG12 | USART6_RTS | FSMC_NE4 | EVENTOUT | |||||||||||||
PG13 | UART6_CTS | ETH _MII_TXD0 ETH _RMII_TXD0 |
FSMC_A24 | EVENTOUT | ||||||||||||
PG14 | USART6_TX | ETH _MII_TXD1 ETH _RMII_TXD1 |
FSMC_A25 | EVENTOUT | ||||||||||||
PG15 | USART6_CTS | DCMI_D13 | EVENTOUT | |||||||||||||
PH0 | EVENTOUT | |||||||||||||||
PH1 | EVENTOUT | |||||||||||||||
PH2 | ETH _MII_CRS | EVENTOUT | ||||||||||||||
PH3 | ETH _MII_COL | EVENTOUT | ||||||||||||||
PH4 | I2C2_SCL | OTG_HS_ULPI_NXT | EVENTOUT | |||||||||||||
PH5 | I2C2_SDA | EVENTOUT | ||||||||||||||
PH6 | I2C2_SMBA | TIM12_CH1 | ETH _MII_RXD2 | EVENTOUT | ||||||||||||
PH7 | I2C3_SCL | ETH _MII_RXD3 | EVENTOUT | |||||||||||||
PH8 | I2C3_SDA | DCMI_HSYNC | EVENTOUT | |||||||||||||
PH9 | I2C3_SMBA | TIM12_CH2 | DCMI_D0 | EVENTOUT | ||||||||||||
PH10 | TIM5_CH1 | DCMI_D1 | EVENTOUT | |||||||||||||
PH11 | TIM5_CH2 | DCMI_D2 | EVENTOUT | |||||||||||||
PH12 | TIM5_CH3 | DCMI_D3 | EVENTOUT | |||||||||||||
PH13 | TIM8_CH1N | CAN1_TX | EVENTOUT | |||||||||||||
PH14 | TIM8_CH2N | DCMI_D4 | EVENTOUT | |||||||||||||
PH15 | TIM8_CH3N | DCMI_D11 | EVENTOUT | |||||||||||||
PI0 | TIM5_CH4 | SPI2_NSS I2S2_WS |
PI1 | SPI2_SCK I2S2_CK |
DCMI_D8 | EVENTOUT | |||||||||||||
PI2 | TIM8_CH4 | SPI2_MISO | I2S2ext_SD | DCMI_D8 | EVENTOUT | |||||||||||
PI3 | TIM8_ETR | SPI2_MOSI I2S2_SD |
PI4 | TIM8_BKIN | DCMI_D5 | EVENTOUT | |||||||||||||
PI5 | TIM8_CH1 | DCMI_VSYNC | EVENTOUT | |||||||||||||
PI6 | TIM8_CH2 | DCMI_D6 | EVENTOUT | |||||||||||||
PI7 | TIM8_CH3 | DCMI_D7 | EVENTOUT | |||||||||||||
PI8 | EVENTOUT | |||||||||||||||
PI9 | CAN1_RX | EVENTOUT | ||||||||||||||
PI10 | ETH _MII_RX_ER | EVENTOUT | ||||||||||||||
PI11 | OTG_HS_ULPI_DIR | EVENTOUT | ||||||||||||||
PI12 | ||||||||||||||||
PI13 | ||||||||||||||||
PI14 | ||||||||||||||||
PI15 |
ADC Mapping
Channel | ADC1 | ADC2 | ADC3 |
0 | PA0 | PA0 | PA0 |
1 | PA1 | PA1 | PA1 |
2 | PA2 | PA2 | PA2 |
3 | PA3 | PA3 | PA3 |
4 | PA4 | PA4 | |
5 | PA5 | PA5 | |
6 | PA6 | PA6 | |
7 | PA7 | PA7 | |
8 | PB0 | PB0 | |
9 | PB1 | PB1 | |
10 | PC0 | PC0 | PC0 |
11 | PC1 | PC1 | PC1 |
12 | PC2 | PC2 | PC2 |
13 | PC3 | PC3 | PC3 |
14 | PC4 | PC4 | |
15 | PC5 | PC5 | |
16 | temperature sensor | ||
17 | VREFINT | ||
18 | VBAT/2 |
STM32F4DISCOVERY Development Board Overview
- (STM32F407VGT6 microcontroller featuring 32-bit ARM Cortex-M4F core, 1 MB Flash, 192 KB RAM in an LQFP100 package
- On-board ST-LINK/V2 with selection mode switch to use the kit as a standalone ST- LINK/V2 (with SWD (Serial Wire Debug) connector for programming and debugging)
- Board power supply: through USB bus or from an external 5 V supply voltage
- External application power supply: 3 V and 5 V
- LIS302DL, ST MEMS motion sensor, 3-axis digital output accelerometer
- MP45DT02, ST MEMS audio sensor, omni-directional digital microphone
- CS43L22, audio DAC with integrated class D speaker driver
- Eight LEDs:
- LD1 (red/green) for USB communication
- LD2 (red) for 3.3 V power on
- Four user LEDs
- LD3 (orange)
- LD4 (green)
- LD5 (red)
- LD6 (blue)
- 2 USB OTG LEDs
- LD7 (green) VBus
- LD8 (red) over-current
- Two push buttons
- user
- reset
- USB OTG FS with micro-AB connector
- Extension header for all LQFP100 I/Os for quick connection to prototyping board and easy probing
Documents and files
- Discovery kit for STM32 F4 series - with STM32F407VG MCU
- STM32F4 high-performance discovery board
- Schematic
- User manual - getting started
- User manual
- Example code
- About example code
Pinout
Available pins on board
Bit | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 113 | 14 | 15 |
Port A | PA0 | PA1 | PA2 | PA3 | PA4 | PA5 | PA6 | PA7 | PA8 | PA9 | PA10 | PA13 | PA14 | PA15 | ||
Port B | PB0 | PB1 | PB2 | PB3 | PB4 | PB5 | PB6 | PB7 | PB8 | PB9 | PB10 | PB11 | PB12 | PB13 | PB14 | PB15 |
Port C | PC0 | PC1 | PC2 | PC3 | PC4 | PC5 | PC6 | PC7 | PC8 | PC9 | PC10 | PC11 | PC12 | PC13 | PC14 | PC15 |
Port D | PD0 | PD1 | PD2 | PD3 | PD4 | PD5 | PD6 | PD7 | PD8 | PD9 | PD10 | PD11 | PD12 | PD13 | PD14 | PD15 |
Port E | PE0 | PE1 | PE2 | PE3 | PE4 | PE5 | PE6 | PE7 | PE8 | PE9 | PE10 | PE11 | PE12 | PE13 | PE14 | PE15 |
Port F | ||||||||||||||||
Port G | ||||||||||||||||
Port H | PH0 | PH1 | ||||||||||||||
Port I |
Usable Peripherals
Note: this is an incomplete list, based on ongoing development and testing
Peripheral | Function | Pin |
USART1 | TX | PA9 (1) |
USART1 | RX | PA10 |
USART2 | TX | PA2 |
USART2 | RX | PA3 |
USART3 | TX | PB10 |
USART3 | RX | PB11 |
UART4 | TX | PA0 |
UART4 | RX | PA1 |
UART5 | TX | PC12 |
UART5 | RX | PD2 |
USART6 | TX | PC6 |
USART6 | RX | PC7 |
DAC | OUT1 | PA4 |
DAC | OUT2 | PA5 (2) |
1) garbled characters received
2) level may be slightly higher then channel 1 with buffer disabled due to external component input pin. Recommended use of buffer.
PCB IO map
Pin | Direction | Connected to |
PA0 | ← |
PA1 | ||
PA2 | ||
PA3 | ||
PA4 | → |
PA5 | → |
PA6 | ← |
PA7 | → |
PA8 | ||
PA9 | ← |
PA10 | ↔ |
PA11 | ↔ |
PA12 | ↔ |
PA13 | ↔ |
PA14 | ↔ |
PA15 | ||
PB0 | ||
PB1 | ||
PB2 | ← |
PB3 | ↔ |
PB4 | ||
PB5 | ||
PB6 | ↔ |
PB7 | ||
PB8 | ||
PB9 | ↔ |
PB10 | → |
PB11 | ||
PB12 | ||
PB13 | ||
PB14 | ||
PB15 | ||
PC0 | → |
PC1 | ||
PC2 | ||
PC3 | ← |
PC4 | ||
PC5 | ||
PC6 | ||
PC7 | → |
PC8 | ||
PC9 | ||
PC10 | → |
PC11 | ||
PC12 | → |
PC13 | ||
PC14 |
PC15 |
PD0 | ||
PD1 | ||
PD2 | ||
PD3 | ||
PD4 | → |
PD5 | ← |
PD6 | ||
PD7 | ||
PD8 | ||
PD9 | ||
PD10 | ||
PD11 | ||
PD12 | → |
PD13 | → |
PD14 | → |
PD15 | → |
PE0 | ← |
PE1 | ← |
PE2 | ||
PE3 | → |
PE4 | ||
PE5 | ||
PE6 | ||
PE7 | ||
PE8 | ||
PE9 | ||
PE10 | ||
PE11 | ||
PE12 | ||
PE13 | ||
PE14 | ||
PE15 | ||
PH0 | ← |
PH1 | → |
Note:
- 1. not free if USB socket in use
CPU core
Programming
IMPORTANT: If using Keil µVision with hardware FPU selected in the project options, please be sure to enable the FPU before any floating point numbers are loaded or processed.
This can be done by setting bits 20 to 23 in CPACR (address 0xE000ED88)
If using C, this can be done by:
#define CPACR (*((volatile unsigned long *) 0xE000ED88)) CPACR |= 0xFu<<20;
If the CPU still crashes then there are FPU instruction before the point the FPU is enabled or it is not in a privileged mode that makes it possible to access the CPACR register (datasheet is unclear).
This assembly code can be used to enable the FPU before main() is run:
LDR.W R0, =0xE000ED88 LDR R1, [R0] ORR R1, R1, #(0xF << 20) STR R1, [R0] DSB ISB
