STM32L031K6 Microcontroller
(Redirected from STM32F031K6 Microcontroller)
Jump to: navigation, search
STM32L031K6 Microcontroller Overview
  • Ultra-low-power platform
    • 1.65 V to 3.6 V power supply
    • -40 to 125 °C temperature range
    • 0.25 μA Standby mode (2 wakeup pins)
    • 0.38 μA Stop mode (16 wakeup lines)
    • 0.68 μA Stop mode + RTC + 8 KB RAM retention
    • Down to 76 μA/MHz in Run mode
    • 5 μs wakeup time (from Flash memory)
    • 41 μA 12-bit ADC conversion (at 10ksps)
  • Core: ARM® 32-bit Cortex®-M0+
    • From 32 kHz up to 32 MHz max.
    • 0.95 DMIPS/MHz
    • Ultra-safe, low-power BOR (brownout reset) with 5 selectable thresholds
    • Ultralow power POR/PDR
    • Programmable voltage detector (PVD)
  • Clock sources
    • 1 to 25 MHz crystal oscillator
    • 32 kHz oscillator for RTC with calibration
    • High speed internal 16 MHz factory-trimmed RC (+/- 1%)
    • Internal low-power 37 kHz RC
    • Internal multispeed low-power 65 kHz to 4.2 MHz RC
    • PLL for CPU clock
  • Pre-programmed bootloader
    • USART, SPI supported
  • Development support
    • Serial wire debug supported
  • Up to 38 fast I/Os (31 I/Os 5V tolerant)
  • Memories
    • Up to 32 KB Flash with ECC
    • 8 KB RAM
    • 1 KB of data EEPROM with ECC
    • 20-byte backup register
    • Sector protection against R/W operation
  • Rich Analog peripherals
    • 12-bit ADC 1.14 Msps up to 10 channels (down to 1.65 V)
    • 2x ultra-low-power comparators (window mode and wake up capability, down to 1.8 V)
  • 7-channel DMA controller, supporting ADC, SPI, I2C, USART, Timers
  • 5x peripherals communication interface
  • 1x USART (ISO 7816, IrDA), 1x UART (low power)
  • 1x SPI 16 Mbits/s
  • 1x I2C (SMBus/PMBus)
  • 8x timers: 1x 16-bit with up to 4 channels, 2x 16-bit with up to 2 channels, 1x 16-bit ultra-low-power timer, 1x SysTick, 1x RTC and 2x watchdogs (independent/window)
  • CRC calculation unit, 96-bit unique ID
  • All packages are ECOPACK®2
STM32L031K6 block diagram
STM32L031K6 clock tree
STM32L031K6 system architecture
Note:
  • only serial controllers USART2 and LPUART1 are available on the LQFP32 package
  • Only one I2C controller (I2C1) is available on the LQFP32 package
  • Only one SPI controller (SPI1) is available on the LQFP32 package
Documents and files
Datasheet
Specifications
Getting started
Reference manual
Programming manual
Errata
Getting started with STM32F0 or STM32L0 series
Cortex-M0+ Technical Reference Manual
Virtually increasing the number of serial communication peripherals in STM32 applications
Guidelines to increase the number of touch sensing touchkeys
Pinout
Alternate function mapping
All dark grey text indicates that the pin is not available on the LQFP32
Alternate Functions for available pins on chip
Pin AF0
(SPI1
USART2
LPTIM
TIM21
EVENTOUT
SYS_AF)
AF1
(SPI1
I2C1
LPTIM)
AF2
(LPTIM
TIM2
EVENTOUT
SYS_AF)
AF3
(I2C1
EVENTOUT)
AF4
(I2C1
USART2
LPUART1
TIM22
EVENTOUT)
AF5
(TIM2
TIM21
TIM22)
AF6
(LPUART1
EVENTOUT)
AF7
(COMP1
COMP2)
Additional functions
PA0 LPTIM1_IN1 TIM2_CH1 USART2_CTS TIM2_ETR COMP1_OUT
COMP1_INM6
ADC_IN0
RTC_TAMP2
WKUP1
PA1 EVENTOUT LPTIM1_IN2 TIM2_CH2 I2C1_SMBA USART2_RTS TIM21_ETR
COMP1_INP
ADC_IN1
PA2 TIM21_CH1 TIM2_CH3 USART2_TX LPUART1_TX COMP2_OUT
COMP2_INM6
ADC_IN2
RTC_TAMP3
RTC_TS
RTC_OUT
WKUP3
PA3 TIM21_CH2 TIM2_CH4 USART2_RX LPUART1_RX
COMP2_INP
ADC_IN3
PA4 SPI1_NSS LPTIM1_IN1 USART2_CK TIM22_ETR
COMP1_INM4
COMP2_INM4
ADC_IN4
PA5 SPI1_SCK LPTIM1_IN2 TIM2_ETR TIM2_CH1
COMP1_INM5
COMP2_INM5
ADC_IN5
PA6 SPI1_MISO LPTIM1_ETR LPUART1_CTS TIM22_CH1 EVENTOUT COMP1_OUT ADC_IN6
PA7 SPI1_MOSI LPTIM1_OUT USART2_CTS TIM22_CH2 EVENTOUT COMP2_OUT ADC_IN7
PA8 MCO LPTIM1_IN1 EVENTOUT USART2_CK TIM2_CH1
PA9 MCO I2C1_SCL USART2_TX TIM22_CH1
PA10 I2C1_SDA USART2_RX TIM22_CH2
PA11 SPI1_MISO EVENTOUT USART2_CTS TIM21_CH2 COMP1_OUT
PA12 SPI1_MOSI EVENTOUT USART2_RTS COMP2_OUT
PA13 SWDIO LPTIM1_ETR LPUART1_RX
PA14 SWCLK LPTIM1_OUT I2C1_SMBA USART2_TX LPUART1_TX
PA15 SPI1_NSS TIM2_ETR EVENTOUT USART2_RX TIM2_CH1
PB0 EVENTOUT SPI1_MISO USART2_RTS TIM2_CH3
ADC_IN8
VREF_OUT
PB1 USART2_CK SPI1_MOSI LPUART1_RTS TIM2_CH4
ADC_IN9
VREF_OUT
PB2 LPTIM1_OUT
PB3 SPI1_SCK TIM2_CH2 EVENTOUT COMP2_INN
PB4 SPI1_MISO EVENTOUT TIM22_CH1 COMP2_INP
PB5 SPI1_MOSI LPTIM1_IN1 I2C1_SMBA TIM22_CH2 COMP2_INP
PB6 USART2_TX I2C1_SCL LPTIM1_ETR TIM21_CH1 COMP2_INP
PB7 USART2_RX I2C1_SDA LPTIM1_IN2
COMP2_INP
VREF_PVD_IN
PB8 I2C1_SCL
PB9 EVENTOUT I2C1_SDA
PB10 TIM2_CH3 LPUART1_TX
PB11 EVENTOUT TIM2_CH4 LPUART1_RX
PB12 SPI1_NSS EVENTOUT
PB13 SPI1_SCK MCO TIM21_CH1 LPUART1_CTS
PB14 SPI1_MISO RTC_OUT TIM21_CH2 LPUART1_RTS
PB15 SPI1_MOSI RTC_REFIN
PC0 LPTIM1_IN1 EVENTOUT LPUART1_RX
PC14 OSC32_IN
PC15 OSC32_OUT
PH0
PH1
NUCLEO-L031K6 development Board Overview
Front Back Dimentions
front back dimentions
Packaging literature
Front Back
front back
Features
  • STM32 microcontrollers in 32-pin packages
  • Extension with Arduino™ nano connectivity
  • ARM® mbed™ -enabled (see http://mbed.org)
  • On-board ST-LINK/V2-1 debugger/programmer with SWD connector:
    • USB VBUS
    • External source
  • Three LEDs:
    • USB communication (LD1), power LED (LD2), user LED (LD3)
  • Reset push-button
  • Supported by wide choice of Integrated Development Environments (IDEs) including IAR™ , Keil® , GCC-based IDEs (AC6 SW4STM32, ...)
Documents and files
Specifications
Getting started with STM32 Nucleo board software development tools
User manual
Schematic
Board Layout
Top Bottom
Pinout
Available pins on board
Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Port A PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 PA8 PA9 PA10 PA11 PA12
Port B PB0 PB1 PB3 PB4 PB5 PB6 PB7
Port C PC14 PC15
Solder Bridges
Solder Bridge fitted connects
SB1 no power configuration
SB2 yes connects VCP-TX (PA2) to ST-LINK
SB3 yes connects VCP-RX (PA15 - not broken out) to ST-LINK
SB4 no connects PC14 to MCO
SB5 yes connects PC14 to X1 (32.768KHz Xtal)
SB6 no connects PC14 to PC15 (shorts OSC32_IN to OSC32_OUT)
SB7 yes connects PC15 to X1 (32.768KHz Xtal)
SB8 no connects PC15 to PC14 (shorts OSC32_IN to OSC32_OUT)
SB9 yes ST-LINK reset
SB10 yes connects VDD to STM32 pin VDDA
SB11 yes connects STM32 pin VSS to GND
SB12 yes connects BOOT0 to GND
SB13 yes connects GND to STM32 pin VDDA
SB14 yes connects 3.3V regulator output to +3V3/VDD
SB15 yes connects PB3 to LD3 (Green LED)
SB16 yes connects PB6 to PA6
SB17 no connects PA0 to MCO
SB18 yes connects PB7 to PA5
PCB IO map
IO connections
STM32 pin Board pin name Board pin number Direction Connected to Alternate & additional functions
see complete AF list
Notes
PA0 A0 CN4.12
  • ADC_IN0
PA1 A1 CN4.11
  • ADC_IN1
  • COMP1_INP
PA2 A7 CN4.5
  • VCP TX
  • ADC_IN2
  • COMP2_INM6
PA3 A2 CN4.10
  • ADC_IN3
  • COMP2_INP
PA4 A3 CN4.9
  • ADC_IN4
  • COMP1_INM4
  • COMP2_INM4
PA5 A4 CN4.8
  • PB7 via SB18
  • ADC_IN5
  • I2C1_SDA
  • COMP1_INM5
  • COMP2_INM5
Limitations on A4 and A5, D4 and D5 related to I2C configuration are explained in Section 6.8: Solder bridges according to SB16/SB18 setting.
PA6 A5 CN4.7
  • PB6 via SB16
  • ADC_IN6
  • I2C1_SCL
PA7 A6 CN4.6
  • ADC_IN7
PA8 D9 CN3.12
  • TIM2_CH1
PA9 D1 CN3.1
  • USART2_TX
Only one USART is available and it is shared between Arduino Nano and VCP. The selection is done by remapping (no need to change the hardware configuration).
PA10 D0 CN3.2
  • USART2_RX
PA11 D10 CN3.13
  • SPI_CS
  • TIM21_CH2
SPI_CS is made by GPIO.
PA12 D2 CN3.5
PB0 D3 CN3.6
  • TIM2_CH3
  • ADC_IN8
  • VREF_OUT
PB1 D6 CN3.9
  • TIM2_CH4
  • ADC_IN9
  • VREF_OUT
PB3 D13 CN4.15
  • LED green
  • SPI1_SCK
  • COMP2_INN
PB4 D12 CN3.15
  • SPI1_MISO
  • COMP2_INP
PB5 D11 CN3.14
  • SPI1_MOSI
  • TIM22_CH2
  • COMP2_INP
PB6 D5 CN3.8
  • PA6 via SB16
  • TIM21_CH1
  • COMP2_INP
Limitations on A4 and A5, D4 and D5 related to I 2 C configuration are explained in Section 6.8: Solder bridges according to SB16/SB18 setting.
PB7 D4 CN3.7
  • PA5 via SB18
  • COMP2_INP
  • VREF_PVD_IN
PC14 D7 CN3.10
  • 32.768KHz Xtal via SB5
D7/D8 shared with OSC_IN/OSC_OUT.
PC15 D8 CN3.11
  • 32.768KHz Xtal via SB7
Note PA15 is the VCP RX, but is not broken out to a PCB pin.
Schematic
STM32L031K6 to ST-Link
STM32L031K6, power, and breakout
STM32F103CBT6 based ST-Link
