ARM: Count leading zeros
This is using the old 32 bit instruction set, modern chips have a single cycle CLZ instruction.
Minimum size
;R0 - value ;R1 = count of leading zeros ;Uses R0-R1 ;Worst case 159 cycles, best case 4 cycles mov r1,#0 loop movs r0,r0,lsl #1 addcc r1,r1,#1 bcc loop mov pc,r14
Maximum performance
;R0 - value ;R1 = count of leading zeros ;Uses R0-R1 ;16 cycles constant movs r1,r0,lsr #16 mov r1,#0 addeq r1,r1,#16 moveqs r0,r0,lsl #16 addeq r1,r1,#1 tst r0,#0xff000000 addeq r1,r1,#8 moveq r0,r0,lsl #8 tst r0,#0xf0000000 addeq r1,r1,#4 moveq r0,r0,lsl #4 tst r0,#0xc0000000 addeq r1,r1,#2 moveq r0,r0,lsl #2 tst r0,#0x80000000 addeq r1,r1,#1 mov pc,r14
Maximum performance with normalising
;R0 - value ;R1 = count of leading zeros ;Uses R0-R1 ;17 cycles constant movs r1,r0,lsr #16 mov r1,#0 addeq r1,r1,#16 moveqs r0,r0,lsl #16 addeq r1,r1,#1 tst r0,#0xff000000 addeq r1,r1,#8 moveq r0,r0,lsl #8 tst r0,#0xf0000000 addeq r1,r1,#4 moveq r0,r0,lsl #4 tst r0,#0xc0000000 addeq r1,r1,#2 moveq r0,r0,lsl #2 tst r0,#0x80000000 addeq r1,r1,#1 moveq r0,r0,lsl #1 mov pc,r14
